Oh, fair enough. In that case, as I went on to say, although not something that most of us would do, or than many of us 'like' seeing (perhaps just because of habit) the arrangement could well be compliant with regs (give or take the couple of caveats I mentioned) and does not really represent any significant 'safety' issue.Sorry, I was referring to the double socket off a ceiling rose in a public area off a lighting circuit (if that indeed is what it actually is).
Opinions will obviously vary as to what is 'stupid' but, in general, if something is 'coded' (as a 'defect') on an EICR that should relate to s non-compliance with some regulation in BS7671. The inspector's discretion comes into it in deciding which code to give. To code as "C2" (which is the 'lowest' code which 'requires' remedial action, the inspector's opinion has to be that the defect is "Potentially dangerous - urgent remedial action required" - and I would suggest that it would probably be difficult to argue that such was the case with what we are talking about.Surely anyone carrying out an EICR can use his discretion if someone is clearly stupid whatever the wording of the regs.
As I've said, in a hotel it's probably unlikley that the lighting circuits are only 6A. They could well be 16A - and, to put that in context, if the socket were supplied by a 20A radial, no-one would be complaining at all. In any event, if there were ever any 'power cuts' as a result of the arrangement,they would surely be extremely rare (not 'frequent'). In fact, as I've said, the only likely large load I can imagine being plugged into that socket is a vacuum cleaner, and that would usually not be being used whilst the restaurant was occupied by any customers.I can understand a socket on a lighting circuit in a discrete place feeding say an under cupboard light but a double socket in a public place in a hotel is something altogether different. Yes an overload will ‘only’ trip the lights but frequent ‘power cuts’ as seen by customers is not good for customer service.
Kid Regards, John
