- Joined
- 29 Nov 2023
- Messages
- 13
- Reaction score
- 6
- Country
Hi All, Our Ideal icos he24 boiler display constantly shows 'c' and the reset does not work. It heats up the water and central heating. But makes loud banging sounds when the CH demand is turning off. Then shows HA over heat error code. After few minutes goes back to 'c' and repeats.
I think if it resets to go back to '0' when there is no demand then the problem will be solved.
My understanding is- when CH demand is off, the motorised valve closes, but the boiler is still on. This heats up the water in heat exchanger to boiling which causes banging noises as water has no where to go. This over heating leads to HA code.
I suspect it is the faulty control pcb which is stopping the reset to '0'. Pressure is set to 1bar after bleeding all radiators.
I am not an expert. Any thoughts about anything else that may be faulty? Your help will be appreciated. Thank you
