Purpose of the rubber and piece of metal in a water engine pump
13 May 2014
I would like to know the purpose of the rubber in the images fixed in a piece of metal.
Best Regards
Make i dont know
Model
Engine size/Type
Year
Mileage
Timing belt and idle pulley in rubber to reduce noise.
May be a tensioner as well but hard to see.
I don’t really get this one......all water pumps that I can recall have been toothed.
It’s only tensioners that run on the back of the belt, but what do I know?
John
John
I think there's a move away from toothed water pump pulleys so that if the pump seizes, (either due to mechanical failure or insufficient antifreeze on a cold morning), it doesn't take your valvetrain with it!
Face of belt drives the water pump, in case of water pump failure the belt will not be damaged (in theory) if it was a tooth drive on pump it would.
I cant remember but some cars used the water pump for the tension of the timing belt(been some time now) lol
That's a new one on me.....I haven't had the pleasure so far!
John :)
Good news. I have an old kit, because the new don't have the rubber or the special piece :
I will attach more next post
other files attached :
more attached files
At the present times the distribution kit don't have the rubber or the special piece....
Some Vauxhalls did. I only remember that as I was having a sort out of my tool boxes the other day and found a special spanner that I used to adjust them with. This type:
