- Joined
- 14 Sep 2020
- Messages
- 32
- Reaction score
- 2
- Country
Hi All!! Thank you for your replies!!
After further investigation it seems like a few of you were correct! The lugs on the top are not spring loaded. So, I removed the torx screws on the bottom, bent the metal tabs back into place (I originally thought it was hinged!! Good job the table was in front otherwise it would have dropped all the way down and probably snapped the tabs off!!), I slid the panel over the lugs and the panel popped straight back into place. Re fitted the screws! All good!! The only thing that could have possibly happened, is a while ago I had to have a part replaced (covered by British Gas!) The 'engineer' obviously didn't latch the cover over the top lugs? There is no other way it could have come off. Impossible!! I am still going to get it checked over anyway as it's due a service.
Thanks again and Merry Xmas!
