Have had an outhouse in the garden rebuilt. Roof was designed to be essentially a flat roof with 10 degree single pitch with reclaimed hand made pantiles as a covering to make it look prettier with a.
Seems the builder didn't quite get it and installed it as follows:
20mm marine ply, tyvek waterproof membrane laid directly on it and then battened across for the pantiles to hang off.
Issue seems to be water building up on top of the membrane behind the batons then seeping through and also condensation patterns on the underside of the marine ply.
Have asked another builder friend and he's come up with a solution but I'm not sure about it. Take off the old roofing down to the ply, put batons running down the pitch of the roof, put an impermeable membrane down (thinking either EDPM or bituminous underfelt) then cross batons to hang the tiles off.
Any ideas or thoughts on this would be very welcome indeed. Just starting to put my materials order together.
Many thanks
Brian
Many thanks
Brian
