Not at all, I would say.The electrons care little, or not at all, what the colour of the plastic insulation is -the colour is simply for identification by the installer, and those who might follow.
Exactly. As I wrote, I certainly wouldn't personally describe it as 'very undesirable' - and, as I also wrote, presumably less desirable than (non-compliantly) leaving L and N both identified only by brown insulation.Not really any different to using brown and blue cable for a switch drop when you have to put brown sleeving over the blue. ... Not really any different to multicore flex or swa where the cores ate all the same colour, but do have numbers printed on them. ... It's inconvenient, definitely will give the next man something to think about, but I seem to recall pyro would have black sleeves on each conductor, and that had to belled out, and then the live wire was (nearly always) identified with a piece of red sleeve or similar.
I feel sure that's the case but, as above, I would certainly advise oversleeving the appropriate brown-insulated conductor.- not the least so as to achieve compliance with BS7671.If it doesn't break any rules, and it's not easy to replace, then it's going to stay that way - I would imagine.
Nor do I. I can't understand why someone came up with idea (for both single-phase or 3-phase) of brown being used to identified line/phase/'live' conductors - since that colour is (I would suggest 'obviously') associated with ('the') earth in most people's minds!And we have only mentioned single phase colours. .... Three phase .... "New colours" (No I do not like them)
At the time there was an expression 'George Brown is a live wire'of brown being used to identified line/phase/'live' conductors - since that colour is (I would suggest 'obviously') associated with ('the') earth in most people's minds!
Trouble is, it looks like a cable toe rather than an indicator.Fwiw I use small brown cable ties on blue cables to identify SW live
Exactly I would say that it is almost universally regarded as a 'danger' - so was the obvious choice to identify line/phase.I think Red was a good colour for a Line (Phase) conductor. It is often associated with danger, maybe one reason because blood is red ...
Yep, agreed. Again, at least these days, often with danger/warning connotations ('high vis' items, road warning signs, even the background of electrical 'warning labels/signs' Etc.)If we need a second Line/phase colour the Yellow seems Ok to me,
Maybe - although it feels a bit like a 'harmless' colour to me I think I'd probably personally favour something like purple or violet.Blue, a nice bright colour too and again one of the six. So I like Blue for the 3rd Line/phase.
Agreed - and, again, I would say the 'obvious' choice for N.Black to me suggests a good choice for N so I am happy with that one.
I was happy with green and also am with G/Y. As I recently wrote I think brown evokes thoughts of 'earth' in most peoples's minds, and green is probably not that far behind (grass etc.) - so, were I 'starting from scratch, I'd probably choose one of those two.and, although I was brought up on Green for Earth, I think that Green/Yellow was a sensible change as it also stands out a bit better to some of the less sighted people.
True, but if one were creating something which "stood out a bit better to some of the less sighted people" would it not have bene better to use that for line/phase? In fact, what about red for line/phase, with the second two phases having different stripes (maybe differnt in 'type'as weell as colour)?Green/Yellow was a sensible change as it also stands out a bit better to some of the less sighted people. .... So I was happy with Earth to be the only two colour combination.
You are not aloneSo yes I am pretty much a fan of our "Old Colours" but not really of our "New Colours" I`m afraid.
Good comment there lad.Maybe - although it feels a bit like a 'harmless' colour to me I think I'd probably personally favour something like purple or violet.
Again that has some merit too.True, but if one were creating something which "stood out a bit better to some of the less sighted people" would it not have bene better to use that for line/phase? In fact, what about red for line/phase, with the second two phases having different stripes (maybe differnt in 'type'as weell as colour)?
T'as oft been quoted on here and hopefully will continue to be so to clarify older instalations.Interesting article from the IET, about conductor colour identification here...
The history of colour identification of conductors
We consider identification of conductors by colour as the norm today, but it wasn’t always the case, as prior to 1916 conductors were not typically identified by colour.electrical.theiet.org
