I’m planning a new kitchen and moving my oven to a different position. Will the existing feed which is a 32a breaker with a 6mm cable be suitable for this induction hob or will I need thicker cable?
Thanks for that. Have one more question. As I’ll be using that oven feed for my hob, I will be having a single oven and a combined microwave oven in a different position in the kitchen. I don’t have any spare breakers in my consumer unit so will that need upgrading/replacing or could those two ovens be hard wired into the kitchen circuit? Here’s the spec for both of them.To my knowledge there isn't an installation method that can't supply 32A on 6mm, so the breaker seems appropriately sized and matches the hob spec (which will be a max, not a nominal) so, no problem..
As you're reusing an old cable that will have had plenty time to oxidise etc, make sure the ends of the cable are in good condition, clean and securely attached to any replacement socket/outlet
It’s what I would call a 2.5mm ring main circuit. Is that the same?Is it on a 2.5mm ring final?
Yea, the sparky's on here don't like it to be called ring main for some reason.It’s what I would call a 2.5mm ring main circuit. Is that the same?
They were once called Ring Mains in textbooks from the 50's so perhaps it's an old one!Yea, the sparky's on here don't like it to be called ring main for some reason.
the ring concept was already in use in the distribution cabling of the DNO's works, which were 'mains' and hence those arranged as rings were 'ring mains.'What is a 'main'?
Electricity mains?What is a 'main'?
It’s the main circuit in the house back when there was just oneYes, I know the 'mains' are (still) in the road -
but if a circuit in the house were a 'ring main' then what is a "main"?
