Wintex Connection Could not be Established
21 Apr 2008
Lincolnshire
Hello
I am connecting with Wintex for the first time and not sure why it will not connect
I created a new site and added the upt password in the site details.
When I connect using PC-Com it just says reading panel type and serial number then after a few moments an error saying it can not connect
Is there anything else I needed to do?
Did you go into engineering on the panel and put in a UDL code ?
One was already set I suspect for my SmartComm module for setting and unsetting the alarm.
I also try connect via that but it says the same error.
I plug the cable into the engineering keypad plug on the left hand side of the board.
No ….it plugs on the com port ….the smartcom takes com1 and 2 , you would have to use the com port + adaptor or connect via smartcom
You mean the one top middle where you put the red ribbon cable on the left with the 1.
I did that also and got same error.
I also get same error with SmartComm which works fine on the app?
You can’t just unplug the com port and plug something else on ! ….post picture of your panel pcb …
Thank you, attached is the two ports I tried.
Top one with the PCB adaptor and switch on PROG and the other with the cable directly.
Comport + plugs onto digi modem giving you an extra com port
So I need to solder this on to my panel? Is there no way to use it without soldering it on?
Or can I unplug the smart comm and use com2 then replug back in after I'm done?
Think I've solved it. I unplugged the COM1/2 and connected the Wintex cable to the Com2 and boom she connected.
Really appreciate all you help.
