Hi all,
I'm looking to convert my new garage intk additional room used for working in.
It's single skin detached with a pitched roof newly built (if that makes a difference).
Obviously I want to make this into a normal room adequately insulated and holds of the mould that seems to appear after a while currently.
I will get the garage door bricked up with a upvc window. I will board it all out myself and then get a plaster in to skim it over.
Am I best to use 25mm celotex with plasterboard over the top fixed to studs on the walls (25mm to maintain as much internal space as possible) then either larger diameter celotex in the roofspace or rockwool.
Or.. dot and dab insulted boards directly to the wall although don't think most of these come with a vapour barrier which may be needed?
Does this seem okay or am I missing anything obvious?
There Is damp proof membrane above the damp course bricks but I have also brought dpc gel to insert into the brickwork.
Thanks in advance..
Thanks in advance..
