This is my first post on DIYnot so I'll start with a big thank you to everyone who's posted and answered here over the years - you've been invaluable.
I'm in the process of a kitchen renovation, which will include me doing four electrical jobs. I *think* I know what I need to do but I'd be grateful if you could check my homework before I go any further.
1) I'm replacing an electric range cooker with a separate hob and two ovens. The maximum load of the old range was 16,485W while the three new appliances combined are 13,650W so, as I never had any issues before, I'm planning on sticking with the current 4mm circuit wiring and 32A fuse in the consumer unit. However, the specs for the two ovens note the need for 16A fuses so my plan is to add a second consumer unit after the oven switch and then connect the two ovens to two 16A MCUs and the hob to a 32A one (given it's 7,350W by itself). The diagram below explains the plan. This might be overkill but is it OK? The second consumer unit will be hidden in a cupboard so I'll keep the oven switch on the wall so I can quickly and easily isolate the appliances if needed.
2) There is already a spur off the sockets ring terminating with a connection box - I've never used it but presume a previous owner of the house had a fridge running off it. As the spur is fused, am I right in thinking I can run three sockets off it?
3) The renovation has involved removing a stud wall and, in it, I found the cable taking power to the garage - it's a separate 32A circuit running directly off the consumer unit. To reroute the cable, I'm going to have to lengthen it (there's no slack and I'd have to dismantle half the house to pull it through). Am I right in thinking I can cut it and insert a length of similar cable (it's 4mm) using connectors (eg https://www.screwfix.com/p/wago-221-series-32a-2-way-lever-connectors-100-pack/8421r) or terminal blocks (eg https://www.screwfix.com/p/hylec-32a-3-pole-terminal-block-5-pack/26896) housed in appropriate junction boxes?
4) I'll also be moving a light switch and, again, I'll need to lengthen the wiring to it. Will Wago connectors like those linked to above housed in a choc box be suitable for this too?
I'm planning on doing the work myself and then having an electrican test it at the end. Any issues with this approach, please?
Thanks in advance.
Thanks in advance.
