whats annoying is you drill through the soft plaster, then hit the hard lintel and the drill then makes a massive hole in the plaster bit after a whileThe material within is dense because it is vibrated to rid the conc of air.
Yes that is my thoughts too, using a modern Dewalt cordless. I use the hammer sparingly with a small pilot drill then build up the size needed without hammer on.Makes me think that with lots of use an ordinary 'hammer drill' will 'wear' and ultimately, the 'hammer action' will lose its efficacy?
Yes, baggy holes can be an issue.whats annoying is you drill through the soft plaster, then hit the hard lintel and the drill then makes a massive hole in the plaster bit after a while
Yes, that was my thinking more or less exactly.That is good question.
In the above image, parts 53 and 50 look like they are the hammer action components. I guess in time the "sticky out bits" on the rear of 53 will become less deep and possibly rounded.
Is your whole house made out of adamantiumAnyway, a further update in the Bosch CYL-9 vs DeWalt Extreme drill bit test ...
Had a go at drilling four 6mm x 30mm holes for wall plugs in an outside wall which is made out of a very hard engineering-type of brick (Lord alone knows why *shrugs*)
The Bosch CYL-9 drill bit definitely coped better at drilling these holes than the DeWalt Extreme bit - thankfully, I have two further brand-new bits of this type and Screwfix can have the unused deWalt Extreme bit back for a refund!
Dave
Only if your bit is on the small sideYes, baggy holes can be an issue.![]()
... an outside wall which is made out of a very hard engineering-type of brick (Lord alone knows why *shrugs*)
I would bite your hand off to have a house built solidly like that.
If you lived in a new build, you wouldn't need any of those fancy drill bits or drills, there's not a single drilling job you couldn't do internally or externally with just one of these:
Cheese houses. I should know, I'm unfortunate enough to live in one - hopefully moving very soon!
A wolf could blow that downMy stepson's first property- he wanted me to hang a plumbed towel rail.
I soon discovered that the internal walls are 9.5mm plasterboard glued to 25mm plasterboard, with 9.5mm on the other side. The walls are held in place with 1" by 1" batons.
Not all new builds, there are plenty of developers (smaller) building higher spec houses.I would bite your hand off to have a house built solidly like that.
True, but don't see many of them about.Not all new builds, there are plenty of developers (smaller) building higher spec houses.
Quite possibly. Seems highly likely. Maybe I could flog them to the Army as armour for their tanks! I know that most new-build homes are made out of tissue paper, spit, hope & a prayer but I'd like to be able to drill into "normal bricks" for a change.Is your whole house made out of adamantium
Do yourself a favour when you take them back come back with a 3 or 4mm CYL-9 --- ah not sure if screwfix sell them - I think I got mine from toolstation.
