Immersion heater switch?
26 Jan 2013
Cambridgeshire
We have an immersion heater that’s stopped working. I’ve reset the connections and element with a multi-meter and they all seem good. What else could it be? Is it possible it’s the switch? I assume if it were I wouldn’t get a volt reading (with a voltage pen) at the thermostat?
What exactly did you test with the multimeter?
Voltage pen at the switch and thermostat and multi-meter for resistance at the switch and element/thermostat. We used to see a slight spark at the switch when it worked but now nothing.
Are you getting voltage at both terminals on the thermostat?. What element resistance are you getting?.
Also, post a photo of the immersion.
What resistance value, did you measure across the element terminals?
18 (if) ohms, = 230x230/18, 2939 watts at 230V or, 240x240/18, 3200 watts at 240V.
Ohms probably, 240v divide 12.5 amps = 19.2 ohms.
Assuming Ohms, then the element is likely OK. OP suggests they get a live indication with a volt stick, I would suggest the OP checks if the neutral is also showing as being live, with the volt stick.. If so, it will suggest the neutral has somehow been lost.
You could get voltage, depending on how low the voltage pen indicates and they’re not the most reliable. Why not test for voltage correctly?
It would help immensly if we had a photo, it could be a side mounted immersion or a top mounted single element immersion or a top mounted dual element immersion with a short and long element, (unlikely since only one element resistance provided). Below is a top mounted dual element immersion where one thermostat switches the common neutral and has a separate over temp thermostat marked 6.
Yes, 18 Ohms. Tried volt stick at neutral and got an indication. Included a picture as well.
