Diverter valve cartridge vokera unica 28he
28 Feb 2007
Kent
Hi everyone I need to replace the diverter cartridge on my vokera unica 28he but I'm a bit confused by the part number. In the manual the part number is 10025305 but it seems like it might have now changed to 20017597?
I ordered one of these which was listed as fitting my boiler however it's turned up and seems to be the wrong part.
When I look again now online there seems like there's two quite different looking ones with the same part number. Does anyone know if that's the case?
I presume I just get the one that looks like mine, but it just seems a bit strange to have different items with the same part number?
Yes, there were changes in the design.
You could also ring sales 01727 744000 with the serial number
Ok great thanks for that.
So I think mine is the second version then by the looks of it. It only seems to have the square securing pin and the actuator is round.
I still can't seem to find one online with that part number that looks like it tho
Hi again, so I managed to get the new cartridge and swap it over. Had a bit of trouble getting the old one out but all done. Only other thing I did was repressurise the expansion vessel.
Only problem is I now can't get any hot water? Central heating works fine but no hot water. Any ideas what it could be?
Thanks again
Other thing I've noticed is the pump seems to be constantly running I think ,even if I switch central heating off?
I did yes but there was a fair bit of water that came out I must admit when I took the cartridge out so I was a bit worried. I had a good look at the PCB and couldn't see any water on it.
It seems to be suddenly working ok tho now strangely!
Yes it will have dried out now, that was your problem even a minute spot of water will cause that on the pcb
