I'm about to have my supply moved a bit.
The new location for the cut out and meter will be in a surface mounted meter box on the side wall outside my house.
The plan is for the CU to be in more or less the same place on the inside of that wall.
The blurb from Northern Powergrid (and I think also the spec i've read on meter boxes) is that the tails (from meter to CU) aren't allowed to be go out the back of the meter box and they're meant to go out of a knock out in the bottom.
I'm assuming meter tails aren't meant to be out in the fresh air like this so I'm trying to picture what the options are.
Some sort of very short section of trunking then drill them out the back of that and through to the inside of the house where they can go up into the CU? I guess they're not right bendy though?
What might you all do?
Thanks,
Thanks,
