(Disclaimer, I am in no way a qualified electrician and will get someone to look at/do this for me. Just trying to work out what the best approach is).
I'm wondering if I can run two immersion heater elements (3kW each, so 12.5A each) on the same circuit? Getting another circuit upstairs will involve drilling through a 300mm high density concrete slab - which I'd like to try and avoid...
I don't think I can have these both powered up on the same circuit at the same time (MCB is rated to 16A, cable is 32A (I think), and the timeclock after the fused spur is only 16A). And that doesn't bother me - happy to only run one at once.
So it possible to have these wired up so that they can both run on the same circuit, but so that only one can run at a time? Any risks in doing so?
Any alternative suggestions welcome.
Chris
Chris
