Out of interest what sort of thing would that be that prevents fitting a new CU?Then, providing not a fraudulent move, the electrician is absolutely correct.
It does not prevent, but it may delay, in the real world we tend to be living in the home which is having a CU fitted. So the EICR may change the order of events, if there is a fault on the sockets feeding the freezer, we may want to correct that before we fit the CU so the freezer is not off too long.Out of interest what sort of thing would that be that prevents fitting a new CU?
is a must before starting, if there is earth leakage over 9 mA per circuit that needs correcting first, to simply say sorry you can't run central heating as there it too high an earth leakage, I can book in the job in two weeks time, is not acceptable. Here showing testing whole house, but it takes seconds to test each circuit, however testing for earth leakage and insulation resistance is not all we do with an EICR, and I see no really reason why I should be removing down lights or sockets to inspect and test before swapping a CU.Yep it should always be done (or a major amount of said testing and inspecting accordingly - not just a few quick tests, once any defects remedied then you`d complete the EIC with knowledge that all important defects are remediedWhy only a few times?
People here make out it is standard practice and should always be done.
lack of earthing or bonding for a start, anything that might attract a C1, C2 or FIOut of interest what sort of thing would that be that prevents fitting a new CU?
No - checking that and remedying if necessary is part of a CU change.lack of earthing or bonding for a start,
A bit vague but not really - they could be discovered and rectified when fitting the new CU when of course there might be no faults.anything that might attract a C1, C2 or FI
A few times I have advised an EICR prior to CU change
Changing a CU is changing a CU, if you include checks by I & T properly then you are (at least a large way) there ref an EICR so we are disagreeing about nothing or practically nothing anyway.No - checking that and remedying if necessary is part of a CU change.
I've only asked to go ahead with the fuse board change atm and not agreed the EICR only quoted. As I originally asked for the quote to be split into two.
Not quite, that would seem the sensible thing, but it is down to the owner not the electrician if the electrician is not a scheme member.So he owes you an EIC and if a scheme member Part P .......................... if not a scheme member he will need to see if your BCO will accept his EIC
I think that some such legislation still exists, but I don't know the numbers/details.Is that contracts of £35 and over/ 14 days cooling off legislation thingy and cancellation rights still relevant fropm a few years back? Trading Standards were quite hot on it once over.
