- Joined
- 11 Jan 2004
- Messages
- 46,190
- Reaction score
- 3,635
- Country
Excuse the pig mess...
Here is our existing TV. It's a 48" set, but we will be replacing it with a 55" set, mounted on the wall behind.
The current TV is almost the width of chest and the larger TV is approximately 150mm wider.
I propose to move the light switches over to the architrave, possibly mounting them vertically.
My dilemma is: do I fix the TV direct to the wall and sink some trunking into the wall, or do I fix some kind of timber structure to the wall, behind which I can run the cables?
The cables will be the power supplies for the TV and a streaming stick, a gaggle of HDMI leads, co-ax, soundbar leads and a Cat 6 cable.
If I go for a timber structure, I'm not sure of the extent of it?
Should I go floor to ceiling and if so, should I continue the coving around it?
