If it is Reform you're hinting at, they are supposedly "aqua".
Although, them being a bunch of bell ends, "purple" would be more apt
No, they’re not.If it is Reform you're hinting at, they are supposedly "aqua".
You like their slogans I guessNo. Nor the Reds. I’m starting to like turquoise.
"Britain needs reform"? I’d say it does. Wouldn’t you or are you happy to let it continue as it is under Conservative or Labour?You like their slogans I guess
Britain needs to swing away from the right wing that it has been headed, I agree."Britain needs reform"? I’d say it does. Wouldn’t you or are you happy to let it continue as it is under Conservative or Labour?
Labour probably isn't the right long term answer, but it's the direction we need for now.
Please, explain why you think Reform, or Conservative is a better direction than Labour.
Policy wise they have 2 areas that are not short term. They can only have an effect in the long term.Labour probably isn't the right long term answer, but it's the direction we need for now.
That's the bit where mottie could (try to) explain why Reform is a better direction than labourPolicy wise they have 2 areas that are not short term. They can only have an effect in the long term.
The NHS idea is shorter term and is seems 2 hospitals are working the way Starmer wants.
It's a funny election really. Not much scope for doing much about money. The Libs have a problem in that respect. Greens - cost of living will go up. Reform loads of money from mad sources that wont be met.
Fiscal rules, hoping I remember the numbers correctly. They have an error allowance. $6b in the Tory case and 12 in Labours case.
Tory extra money - savings in the welfare area when expenditure is forecast to rise.
Why don’t you explain why Labour is the direction we need for now? Why not forever if they’re that good?Please, explain why you think Reform, or Conservative is a better direction than Labour.
Theres not a lot of other choices, other than as token others.
