- Joined
- 2 Jul 2024
- Messages
- 48
- Reaction score
- 1
- Country
Hello all
Considering having a the smart meter installed and thinking if possible to have a isolation switch fitted incase I get a EV charger in the future.
I appreciate this is not a DIY task and only DNO or supplier can touch that fuse inside cutout...and I am not crazy enough to touch it either. I will ask the smart meter installer if they can fit the switch if I supply it and throw in some drinks fund.
Its a old 1900 built house with both gas and electric meter under the stairs and the pipe you see from the bottom left corner is the mains water pipe and condensation does drip...I am assuming reason the consumer unit if fitted about the pipe for this reason.
With this water pipe nearby, is it possible to replace the black Henley block with a isolation switch or keep the block where it is and add a isolation switch. If so where is best location to fit the switch
Any feedback will be appreciated
