When we moved into our 1930s house 12 years ago we had a fair amount of electrical work done, including a new supply fuse, main switch and consumer unit. See picture. According to the certificate the set-up is TN-C-S, earthed on the 'distributor's facility' and you can see the earth wire running down to the block on the side of the supply fuse (which is 3-phase, as our house has a three phase incoming cable, although we only use a single phase). Outside in the flower bed is the old earth rod - a hangover, I vaguely remember the electrician telling me, from the previous installation - but back in 2010 it was not removed and the original thin cable runs from it runs into the CU, although you can't really see it in the picture as it runs behind the main switch and meter. The other day while gardening I noticed that it had become disconnected from the top of the earth rod which sits about 4inches above ground level. Not unduly worried, I simply reconnected it into the chunky screw clamp, but is it normal to retain a legacy earth rod on a TN-C-S system? Does it do anything given the 'certified' earth is on the supply head?
