- Joined
- 11 Jan 2004
- Messages
- 46,752
- Reaction score
- 3,932
- Country
How did you know I wear knickers?
Put the second fitting up in the kitchen.
Took me forever. There were 5 cables going into it.
I sighed heavily, then got to it. Disconnected all the wires. Took down the old fitting, offered the new one up.
The holes in the new fitting did not line up with the cables. Damn.
OK, I can drill a new hole. Marked the position. Went to find cordless drill.
Damn, left it and a load of other kit at my Ma's gaff, including the 25mm hole saw I couldn't find. So broke out the corded drill which is a bit temperamental. Searched for and found my 20mm holesaw. Never mind, I'll drill two holes in an oval shape that will fit a 25mm grommet. Start drilling, damn, the holesaw is going blunt. Cue lots of sparks and burnt paint.
My collection of bits and pieces was at Mum's too, so I had to scrabble round for some plugs and screws.
Then came the joy of fiddling about threading all the straggly cables through the newly hacked hole. There's always one that gets caught and won't pull through the grommet.
Then I had to go upstairs and lift the carpet and boards to ease a bit more of one of the cables through.
Then came the fun and games of connecting all the conductors. Again, my stash of connectors and earth sleeving was elsewhere.
I managed to find 2 terminal blocks, a ceramic block and a Wago.
For earth sleeving I stripped the insulation off a length of 1mm² flex.
I’ve had my downstairs pan out several times over the years with no problem with rusted screws. It has fixings like like this but a bit longer. You need a 10mm socket to remove them and you have a plastic cap that fits over the head and snaps on to the plastic washer to cover the screw head - not unlike those numberplate screw covers.Armed with SDS this time, but lots of too big 8mm drills for brown plugs, actually 8.4mm - I decided the quick fix, was to grind the sides of the bit, down to 7.4mm, using a diamond disc. That worked perfectly, 3" depth holes drilled in seconds.
Looked again today and my existing company was offering a better rate ISA. Not by much but only took a phone call to tell them to move the one I opened the other day into their new one.Two of our fixed rate ISA's and two of our fixed rate bonds mature this week so I’ve been searching the net for better deals. Turned out the company we were with wasn’t that far behind the best offers on the market so I reinvested with them. CBA with isa transfers or withdrawing funds and moving them about.
Used the scooter, to tag along with Avril,
For a moment I had you in a Parka on something Italian with dozen or so mirrors.![]()
Isn't it key operated?
It is impossible to leave my TGA Breeze 4 scooter switched on, unless I leave the key in and turn it to the on position.
But then to charge it, you have to turn it off, then plug in the charging lead.
As TGA recommend you leave it charged when parked, this means I have to remove the key and this turns it off.
