- Joined
- 13 May 2021
- Messages
- 157
- Reaction score
- 6
- Country
Have setup my euro46 panel. Full set A works well for me.
I set alarm, choose A. Timer starts, if I open and close my final exit the timer stops, alarm sets and confirmation noise occurs. When I return open the front door, timer starts, I then have time to unset.
The problem comes when I try to do a B set.
For B set, I want all downstairs on active alarm (I.e. bed). So I setup all the pirs and magnets I want in B, (I.e. deselecting those upstairs from B).
I have to pass downstairs hallway sensor to get to keypad, so I have set that as an entry route (also have to pass that for fullset A - without issue - I.e. it doesn't activate my alarm, atleast not when i come throught the front door)
The problem came last night on first test/use of B. I tried to set the alarm using the keypad, put code in chose B, it said exit via route or some similar words on the keypad, and started the timer (silently as i have setup). But just did not set; it simply just stopped doing the timer noise and instead a very long beep, which lasted an age. Till I came back down and the timer started and unset.
So instead I set via the homecontrol app. Chose B. The alarm then started a timer which was audible (but I have B set with no audible timer). It then set and gave an audible confirmation. Q1 - WHY DID IT MAKE THE TIMER NOISE WITH APP SELECTION OF PART B AND HOW DO I STOP THIS?
Last night, no activations upstairs, so based on the app showing B active, and the fact upstairs sensors did not activate alarm, I'm confident B set. The problem came when I came downstairs this morning, for which the alarm immediately activated instead of starting the entry timer. Q2 - WHAT IS SETUP WRONG HERE?
Q3 - ON THIS ACTIVATION I NOTICED THE INTERNAL BELL SOUNDED, BUT THE EXTERNAL BELL DID NOT, WHERE DO I ACTIVATE THIS/TEST ITS WORKING?
Thanks for the help!
