- Joined
- 27 Jan 2008
- Messages
- 27,783
- Reaction score
- 3,365
- Location
- Country
The wording has changed over the years, but it has been required to run the earth well before 1966 when lighting supplies lost their exemption.A circuit protective conductor shall be run to and terminated at each point in wiring and at each accessory except a
lampholder having no exposed-conductive-parts and suspended from such a point.
I have often wondered what would happen if one asked an electrician to correct his work 20 odd years after it was done, I would think it would be a case of your suppose to do an EICR every 10 years, so why wait until now?
But it would seem silly for an electrician to take the chance, so question is are you sure there is no earth? There was at one point a move to using alitube cable
it did not catch on, two expensive, it was designed so you did not need RCD protection for the cable, this one shows an earth core, but not all of them had an earth core.It could although unlikely fail an EICR, if the earth does not run with the cable, it would be rather pedantic, but to do it right, you don't really have many options, so personally I would just get a class II cooker hood, and take the one you have back, it is just too much hassle to correct the missing earth. You could clearly get an earth to the hob, a metal splash back could be used as the earth wire, but your still doing something which could be removed without the person removing it realising what they had done.Also I didn't want future owners of the property thinking they've isolated the cooker hood from the adjacent switch when it's being supplied from a switch in a cupboard.
This was one of the reasons Part P came in, kitchen fitters were at the turn of the century well known for cutting corners, odd but in England the kitchen is no longer a special location, Part P is now a money making law for the scheme providers, it was in real terms a failure.
The problem even if it complies, with running an earth from another supply, is if the supply in the future is no longer required, then it could be disconnected and so you loose the earth.
As long as you have tested the earth, there is really no problem taking it from else where, but the cheapest tester I can find
is £64, so is it worth it?
