You are assuming the car is owned by the driver, and when that is the case it is likely they can charge at home, but next door had an EV for a week, so not able to charge at home, he had to select where to charge so there is some thing else to be doing while it charges, or get his wife to collect him and take him back once the car has charged.
No, I mentioned nothing about charging at home. However long people spend plugged into their charger at home, is irrelevant. That's their business. I was talking only about public fast chargers.
I want an EV tariff for my battery which is part of the solar panels, at the moment with British Gas, but Octopus is cheaper, so looked at moving to them, but they will not give me the EV tariff without details of the EV car and charger fitted, so I would need car first, before I can set up home charging, chicken and egg situation.
That's odd? I'm with Octopus and signed up for their Intelligent Octopus tariff, (Now called "Intelligent Octopus Go", I think). They didn't ask me anything about my car, although I guess that might have changed since a couple of years ago.
They certainly have a similar tariff for people without an EV though:
Octopus Go
The UK's most awarded energy supplier. We're doing energy better - for you and the environment.
The other neighbour who had an EV an early Kango, it had a range of 140 miles on paper, he used it for a milk round fixed distance of 68 miles, and some times it would run out before getting home, forget the last 50 miles of range, it was the first 50 miles which mattered, just because your car has an extended range does not mean all EV's have an extended range. His problem was if he did not get home early enough, then he could not fully recharge for the next day, and the charge rate for the van was not even 7 kW seem to remember 3 kW did not matter what he plugged into to charge it, so if the public fast charger is the only charger in range, he would be forced to use it at 3 kW as that was all the van would charge at.
I think if it was mine I would carry a generator in the van, but that does kind off defeat the whole idea of an EV.
I can't think of any Renault EV that could only charge at 3kW We have friends with a Zoe, which charges at 7kW (max). Renault backed the ChaDeMo charging plug, (now becoming obsolete), but if you have such a vehicle that can't charge at more than 7kW, then just go to the next suitable charger. The car's sat-nav will have them all programmed in, or you could use ZapMap and just set the filters to only show the chargers suitable for your vehicle.
