I have an underfloor heating system in my house. It is Alpha Innotec, installed in 2006 and it normally works ok.
In the last year or so, I have an app that shows current electricity usage (load) of the house. This shows me that the house is using about 600w per hour at night or when the house is unoccupied, even though the UFH is turned off. By a process of elimination (turning off switches and trip switches), I determined that the underfloor heating control unit (manual attached) seems to be the culprit (not the air-to-water heatpump itself outside the house). It seems to be using around 400w consistently, even when the heaptump is not operating. (I have the UFH switched to 'off' and all the room stats are off). There is no hum off it and no circulating pumps are operating when this power is being used.
When you do the sums, it works out at about £800 per year in seemingly wasted electricity.
I am baffled as to why it would be using so much electricity. Any thoughts as to what the problem might be?
Thanks very much for any comments. Picture below shows the grey control unit in the hot press (the error message on its LCD is just because this is an old pic - it doesn't currently show an error message).
