You got meProbably cross 'cos he had to go out?
I am a good friend.
Think I found the purist in the group..The "pull cord" is not attached to (or detaching from) the ceiling.
It is attached to a "Switch", which should be properly attached to the ceiling.
These were the Rawl plugs used and they are suitable in plasterboardIf the "Switch" is currently being held up by a "Rawl Plug" ("Trade Name" for a plastic "Wall Plug") - and screw -
the ceiling must be Concrete (or similar "Masonry"),
since a "rawl plug" is not a suitable fixing to use on/in a "Plaster Board" ceiling.
Respectfully, @FrodoOne it's the weekend. Can we not be so uptight?
Oh I like this...However if left on, so no one pulling at the switch, then should be safe enough for a week or two, and a 15 watt bulb left on for two weeks will cost around £1.60 so just leave it on until you get there.
So it's perfectly fine to tell someone in a similar situation to just keep the light on, until the repair is complete as it costs 'peanuts'..
Very interesting. Thanks
Edit: Just seen @DetlefSchmitz post
