- Joined
- 11 Jan 2004
- Messages
- 46,501
- Reaction score
- 3,792
- Country
Is this CU rated for external use?
I stayed on a site owned by an "electrician" around the chemical disposal area were a couple of bulkhead fittings, they were wired via round Ashley indoor JB, rather that using the correct kit he had built a small wooden shelter around it,a bit like a bird house. As an aside the toilet shed had a red light on to indicate occupancy and on the back of the door was a photo of the owners beaming down on you as you went about your businessI must admit I have looked at caravan hook up units View attachment 356347and clearly designed for outside use, but seems little protection against the weather. View attachment 356349 is this any better than unit shown? I would mount them in something like a bird feeder so the unit is not in direct rain, but seen them out in weather and seem to work OK.
Completely agree, wonder how many have had the cover smashed off with kids playing football.Certainly not.
Even the ones that claim to be and have seals around the cover are not.
Consumer units go inside the property. This trend created by the EV slingers shoving them on exterior walls needs to stop.
Those CPN things are only IP65. Not enough, IMO.Certainly not.
Normal CEEFORM sockets are only IP44 (there is an IP67 variant too, but they are very much the exception not the rule) and they are used outside all the time.Those CPN things are only IP65. Not enough, IMO.
