Why do you want a new consumer unit?
Entirely untrue.Yet the regulations would force you to excavate the entire wall to replace them causing huge amounts of dust and mess.
If the installation is designed and installed properly, nothing plugged in could cause any wires to melt.The risk of fire depends on what you're plugging in. A phone charger is not going to draw enough current to cause the wires in your walls to melt is it.
No idea what 'regulations' you imagine apply here, or how you think they might be enforced.All these safety regulations are not always proportionate.
A phone charger is not going to draw enough current to cause the wires in your walls to melt is it. About 50% of the sockets in my house arent even used at all in which case what risk of fire is there?
its building regulations. its not optionalWhy do you want a new consumer unit?
Are you extending/adding any new circuits?its building regulations. its not optional
i think the house is about 60 years old?The only flames I’ve seen in our house came from the DC side of a phone charger !
Load isn’t the reason for faults or electrical fires - poor diy work, old installations and rodent damage are all triggers
Do you have any idea of how old the wiring is ? How old is the house ?
i added an external AC and this has opened up can of worms. Theyre saying it cant be plugged in to socket. But it cant be wired back to the fuse box since its too old. And they wont replace the fuse box without rewiring entire house. Its ridiculousAre you extending/adding any new circuits?
thats my understanding. Its not easy to find out because different people say different things.Er - really ?
Maybe there is no need for it and they're trying to up-sell you unnecessarily. Or maybe the rest of the installation is decrepit and they think that as soon as they make any changes it's going to set off a cascade of other failures that you'll blame them for. I suggest you get a couple more quotes.they wont replace the fuse box without rewiring entire house
If that’s the case and the wiring is original, then you should be saving up for a rewire and new CU
No it isn't.its building regulations. its not optional
so where does this rule that you cant plug a fixed appliance into the wall socket come from?No it isn't.
Who told you that, and why?
Are you doing some alterations? Are you turning it into a HMO?
