I took independent building control inspection from the council so it was not a private approved one from the builders themselves (they were not mates). I took all the steps to ensure no ****ups and I got one anyway.Could be a lot worse to be fair, you’re hardly out of pocket.
I’d be tempted to try and stir up why the building inspector signed that off (for his mate) but probably pointless
I can only think the structural engineer specced it to add strength (and to cover his back) as otherwise I am not sure why (the doors to be installed are sliding doors).I don't know why you have that steel, unless hanging bifold doors from it? An off the shelf single leaf lintel would normally be used - galvanised and no SE needed.
I cannot paint it in the section where it has the brickwork installed in the web correct? I could still do the paitning on the lower flange and underside I suppose + the Storm Dry on the brickwork above - that's the best I can think of hmm...Thought the requirement could be met by painting it rather than it being galvanised
What I meant by painting is cold galvanising it. It is Red Oxide yes so it is primed but if the beam is to be used on an external wall it apparently needs to be galvanised (not only Red Oxide) to meet the requirements.I meant given it’s already red, I assumed it’s been painted as opposed to bare, and is ok.
