Connect wires to Ikea barometer light
9 Oct 2024
Hi everyone,
My wife just bought a new light with a live and neutral wire connection. So far so good. But when I removed the previous light, I discovered a more complex installation and I have no clue which one could be the live and the neutral. The previous installation didn’t have a L and N set up either…
Can you please help me?
Brown is L
Blue is N
Green&yellow is Earth which you don't need. Terminate safely and position out of the way.
Thank you so much for the very quick answer. I’ll try tonight when I’m back home.
Brown is L
Blue is N
Just to confirm with you please. I cut the L , N and earth wires shorter so I can remove the white plastic holder which prevent me to fix the new base. I mask the earth wire with insulation tape and then connect the L and N and fix the base. Would it be safe? Any tip to put the earth wire out of the way? Many thanks.
Or easier one of these
