- Joined
- 11 Mar 2024
- Messages
- 33
- Reaction score
- 2
- Country
Hi Andy, that's coming from the boiler - condensate pipe I think?What's the white pipe behind the waste trap in picture 2 from?
Andy
Andy
That's the condensate run by the looks of it m8 - you can see it tracking along the back, then heads forward and down at the left corner behind the drain hose and then across into that saddle clamp.What's the white pipe behind the waste trap in picture 2 from?
The Mcalpine waste/trap setup will fit any standard sink waste outlets. Well most of them, some seem to be a little tight into the sink waste hole and need altered a little.Thanks so much Madrab for the extensive response, really appreciated! I feel like he rushed this too, its already leaking a bit where the sink waste meets main waste pipe. I have a new IKEA sink, but guessing McAlpine system could still go into this, perhaps with some adapter? Cheers again - giving me much needed information!
Thank you so much! Yes, I saw there were these available that might allow Mcalpine fittings to be used on the IKEA sink?The Mcalpine waste/trap setup will fit any standard sink waste outlets. Well most of them, some seem to be a little tight into the sink waste hole and need altered a little.
Here are some photos of full set up. Is the grey fitting the trap in that case?
Good grief, what an unnecessary mess!
Nice one Rob - I saw in the reviews for this that people have attached it to IKEA sinks before, so if needed I could swap this for whats there currently, then proceed to fit all Mcalpine from there:Would really need to see what the connection is when the grey lower half was removed from the sink waste. If that's removed and it's a standard 40mm then you don't need the adapter, the whole sink trap setup will fit as is. Worst case is you need to change the actual sink waste to a standard basket strainer waste, if it's a standard sized waste hole of course.
Definitely - ideally tho, you would use a McAlpine strainer waste - they are more expensive but much better build qualityNice one Rob - I saw in the reviews for this that people have attached it to IKEA sinks before, so if needed I could swap this for whats there currently, then proceed to fit all Mcalpine from there:
Yes, turning the bottom valve handle horizontal will indeed allow water to flow to the dishwasher, BUT it will turn off the water flow to the washing machine. The arrangement of the valves that your"plumber" has fitted cannot supply water to both the washing machine and dishwasher at the same time. The 3 way lower valve needs to be replaced with a T-piece and a 2 way valve feeding the dishwasher should be fitted to the branch from the T-pieceOk brilliant thanks everyone, so my picture shows the bottom connection as OFF. Plumber left it that way, so wondered why the dishwasher wasn't working...will turn it horizontal. Cheers
Oh god, the list grows...! Thank you Chris for flagging this. I will get him to try it out first hand so he can see it for himself.Yes, turning the bottom valve handle horizontal will indeed allow water to flow to the dishwasher, BUT it will turn off the water flow to the washing machine. The arrangement of the valves that your"plumber" has fitted cannot supply water to both the washing machine and dishwasher at the same time. The 3 way lower valve needs to be replaced with a T-piece and a 2 way valve feeding the dishwasher should be fitted to the branch from the T-piece
