My head's up my ...
16 Sep 2006
Fife
AR5E!!!
Not a disaster as such but a 100% doh! moment.
Cutting some laminated wood today with my small circular saw. It struggled (operating at its maximum cutting depth) so much so I had to take it VERY slowly and even then I thought I was going to knacker the thing. Anyhow I got through the job.
I'm sitting here thinking about it and just thought 'You complete idiot! Why make the thing struggle doing one pass at maximum depth?!? You should have done two passes at 50%.'
What was the laminated wood that was thick enough to be the max for your blade.
Maybe its time for a new or correct blade for the wood.
how thick was it ??
was it dry??
was it fully supported so on the final cut it wont move ??
was the blade sharp and rotating in the correct direction??
was there any burning ??
was the blade set to 2 teeth 3mm clear off work ??
a saw should cut the maximum depth it can cut with reasonable ease on most cuts but even iff struggling a bit a second half depth cut should be very very unusual
is it battery if so how old
if mains is it on a long extension
I think part of the reason was my rush to get the job done. I don't mean physically rushing the job (safety first and all that) however I just went for it instead of giving it a bit more thought.
16mm melamine covered chipboard.
Dry.
Fully supported.
Decent enough blade, correct direction. (However it was a general wood/metal blade with 40 odd teeth. I have a wood blade with 20 odd teeth that would possibly have got through the material more quickly and with less stress on the motor, however I needed a cleaner finished edge.)
No burning.
Blade was 3-4mm clear through.
400w (maybe 500w) mains powered saw.
I suppose my point is, regardless of all that, I could have made the job considerably easier for myself (and the tool) if I'd done two passes per cut instead of leaving the tool to struggle. Unfortunately I thought about this a few hours after doing the job rather than during it!
I would expect even a bottom of the market circular saw to eat 16mm chipboard, what saw is it?
Standard 16mm melamine chipboard should cut like hot knife through butter. You need a new blade. I recommend having a look at Saxton blades and maybe get on with a thinner kerf if your saw will take it. I think those wood/metal blades are quite thick.
I am searching for a blade for you, can you confirm that this is your saw.
Older version of this. If you look at the pic, I used the blade on the left.
Maybe the blade is shot, however it's not been overly used and doesn't appear to be.
Ahh that is why people are perplexed when you said circular saw we were all thinking something like this.
Yeah I did say 'small circular saw' in the opening post however should maybe have clarified :) I did begin to wonder with some of the replies 'they're thinking I'm using a full size saw.'
And that thing - or at least that new version is Almost £120 - you could of got a "proper" saw for that.
I have this one but you can not get it any more.
