- Joined
- 11 Jan 2004
- Messages
- 46,218
- Reaction score
- 3,655
- Country
I did!noseall will deny that anyone ever said they were secure.
I am!I think that is stating the obvious, nothing is completely secure.
Good morning Secure.I did!
I am!
sounds like you didn't understand anything.I do understand a SM is simply a meter yes. And continues to be a meter just like my old meter even though it has stopped singing and dancing, yes.
I do understand a SM can be turned off - yes.
I do understand that millions of analogue meters were replaced with pre-pay meters yes and you attempted to make out that was a SM issue and you looked a tw@ - yes.
I do understand you tried to ridicule another poster when he said getting a court order to enter a home was easy, when in fact millions of these orders were waived through - yes. The poster was correct and you looked a tw@ - again.
I do understand that a SM is no different to a dumb meter in terms of the processes leading to being cut off - yes.
I do understand you are no more likely to be cut off or switched to pre-pay with either meter - yes.
I do understand that OFGEM paused meter switching but lacked the authority to impose a permanent ban, were not in favour of a permanent ban, and the practice has resumed - yes.
Then what is the purpose of the relay inside the "meter". A relay that when energised will disconnect the Live supply to the house.I do understand a SM is simply a meter yes.
Your understanding is incorrectI do understand that a SM is no different to a dumb meter in terms of the processes leading to being cut off - yes.
re gas we wont all be forced to have them they will be too busy changing all the existing smart meters when they have either developed a fault or the unchangeable batteries within them give up.
For the so called smart meter experts in here if the gas smart meter just turns off for no reason as is a really common problem do you think they should just communicate with it from the office and turn it back on no need to manually visit the job thus saving on down time and manpower?
1 no shyte sherlock and what do you mean for the gas to be switched off ?You do realise, don't you, that the battery has to be working, for the gas to be switched off, or record consumption?
Once again... By far the most prevalent faults, are the IHD failing to connect, or the comms back to base failing to connect, and report meter readings. Basically, that needs the customer, to revert back to reporting readings.
Read my post again, when you are sober.Your understanding is incorrect
With a "dumb" meter one has to visit the meter location and remove the DNO fuse from the cutout.
With a "smart meter" that has the disconnection relay there is no need to visit the meter location,
2 try answering the actual question
so thats a you havent got a clue , glad you cleared that upStop sniffing the gas sherlock, it's having a serious detrimental effect on your mind..
You'd think that would please the luddites seeing as they yearn to be able to read their own meter and send the reading in manually.Basically, that needs the customer, to revert back to reporting readings.
so your saying the process right up to the meter actually being cut off is the sameRead my post again, when you are sober.
The processes leading up to be cut off are exactly the same for both meters.![]()
