- Joined
- 24 Jan 2021
- Messages
- 22
- Reaction score
- 1
- Country
Yeh do fear that but how would you know.Don't be too surprised if your pump is dead they really don't like that sort of crap .
We would just replace.
It's still not running.
Defo learning that the hard way.Boilers are often routinely left idle for ~ 5 months of the year if not used for reheating a HW cylinder so vital IMO to fire them up for even 5 minutes every fortnight or so, I do this with mine since I have Solar Thermal and I havn't had a single (not one) combustion failure in 19 years, probably helped as well that I've never left my kerosene tank run dry, still though pretty remarkable, a Riello G5X burner.
I really wouldn’t give that pump a second chance......it needs replacing now.
Start at the tank filter / water separator , run some kero through afterwards to see if it’s clean.
Work on to the burner, consider another filter before the kero enters the house.
Pumps have their own filters too, and there’s one on the back of the nozzle too.
Replace the nozzle, they are made under clinical conditions and don’t like to be interfered with.
Good luck with it!
John
Essentially but I can't see any air in the system now.Is the boiler igniting, running for a few seconds and then locking out?
I wouldn’t fiddle with the nozzle, it can lead you up paths unknown!
John
I tested with a multi meter and had no problems, can they be faulty and still send a false signal? I have a spare which I know works as it was a boiler stripped from a working system well serviced that was replaced due to a jacket failing on the water tank.If the photocell is faulty, or it can’t see the flame, the burner ignites as usual then goes into lockout within a few seconds.
You can actually have the burner just out of the boiler if that’s possible, but of course light mustn’t get in. A reasonable way to check!
John
So it's unlikely to be that, but I can certainly replace it with the other one, as it's the same model of burner, I didn't see anything of it being coded to anything when part referencing if that's what you mean?The photocell is supposed to be matched to the control box - I don’t know how vital that is.
The photocell is just a light dependent resistor, high resistance in the dark, very low in full light.
It needs to be clean and be able to see the flame.
John
That’s good, so if you disconnect the flexy hose at the burner you can bleed fresh fuel through into a jar and look for water or other grot in it....an easy one!
John
