I have a set of standard 240 LED lights set with an 8 function controller. However, it has no memory so every time the lights are turned on they have to be set to static. Therefore, can I remove the controller box and connect the lights direct to the transformer? If this is possible can someone please advise about the wiring as there are two wires into the controller and then three on the lights' side, so what would I connect to which? I assume the two from the transformer are positive and negative and then the three on the lights' side are possibly two positive and a negative, so would it be simply the case of connecting the two positives together to the transformer single positive and the negative to the transformer negative. Alternatively, perhaps as I don't want the multi function ability, I would only need to connect two of the three wires on the lights' side. Grateful for any advice.
