Help! Swapping double socket for two single sockets with a junction box
10 Apr 2014
London
Can anybody help?
We have run two tumble dryers from a double socket outlet in our utility room for over 5 years (unaware that this was unadvisable). This weekend, the dryers stopped working and when testing the socket (fuse board had not tripped) , it was not working. Research advised i should not simply replace the double socket but install 30a junction box and run two single sockets. I have installed as per photos but the sockets do not work. What am i getting wrong here?
(i know i need to sleeve the earth wires but would this be enough to stop the sockets working?)
All wisdom gratefully appreciated.
The cable probably is powered from a nearby socket. Have you got a multimeter? Look around the room, can you see any fused spurs?
Hey, thanks for the quick response.
It looks like there is a fused spur feeding a external ventilation fan. There is also a fused switch powering the freezer which is in a fitted cabinet on on the left of the tumble dryer in the pic above. I have attached a pic below, as it looks like there is two t&e cables connected to the switch
For clarity, this switch sits on the same wall, about a meter from the double socket that sat behind the tumble dryers
It's quite difficult for a cable to go wrong.
Quite easy for connections.
Have you got a multimeter or any other testing instrument?
The problem isn't specifically with sleeving from Screwfix, but anything at all involving them.
Never had a problem with them, any faulty gear is replaced without question, what's your problem with them?
