Do these compression need changing?
This is absolutely fantastic, thanks for taking the time to do this.
It will trim down the pipework and make it look alot tidier. Appreciate it ,
Ballofix isolation valves (type with slotted actuator, as in your pics) are notorious for leaking from the slotted screw, when they are turned off and back on.
If this happens, best to change them.
Fridge drinking water often needs filtering to stop limescale and other debris from blocking the small waterways that make up the delivery system within the fridge/freezer.
Thanks for the advice - yes the fridge has it's own separate filter :)
In the end patched it with some speed fit.
Even despite it being snug watertight and lined up I am struggling to tighten this speedfix connector up anymore where it connects to copper any more it feels quite stiff. Does all look ok?
If you're referring to the speedfit collet, then it only tightens to close the gap between it and the mating face.
It's not compression, it is to lock the release ring out which, in turn grabs the pipe.
Hi just going to adjust a bit of copper that had a speedfit on. I have removed the speedfit.
Looking at the pipe its a little scratched from where the speedfit was pinching on and doesn't feel as smooth.
Can I reuse this section of copper and reuse the speedfit over it ? or should I cut it out so there is a fresh section of copper for it to grab to? Thanks
