Hello, can anyone help me please? (apologies for the layman's terms in places, but I hope you can understand what I mean). We had a new radiator installed today by a reputable plumber, as the old one had slush and would no longer heat up. I'm told the existing pipework was also flushed out. It's on the ground floor, at the end of the chain and shares a downward drop pipe with another radiator upstairs (also attached to no other radiator except this one). The new radiator heats up well, but when it and the upstairs radiator are both on, only one heats up. If one is turned off, then the other one heats up, even if the thermostat valves of both are set to lower than full on. This never used to happen and both radiators used to work perfectly at the same time. The pipes going into both radiators also appear to be hot, even when one radiator is cold. Baffling! Is there a reason for this and anything I can do to rectify it please, before I go back to the plumbers and complain? Any help or advice greatly appreciated.
