Hello, I've seen a similar post here but not quite the same, mine is for three hard wired appliances.
Going from one oven to two plus an induction hob replaceing a gas hob. I'm after a 3 cooker wiring diagram , I'm guessing it will involve 2x duel cooker plates or 60 amp junction box.
Second part of my question, the smaller oven (built in microwave combi) spec states "Required Fuse (A): 16" How do achieve this on a cooker circuit? it has a cord but needs hard wiring.
It's your standard 32amp MCB >45amp isolater> single gang cooker plate at the moment. I can't remember if it's 6mm or 10mm cable until the old oven comes out.
Fyi - I trained as a sparky in my younger years so responsibly competent if not fully up to date, a part P registered will be doing the final fix sign off.
