Hey all,
I bought a house and it consists of a extension and the extension has a new small mini little consumer unit but the main house fuse box is the old wylex boxes where the fuses are with fuse wires that need replacing if they pop.
I’m no electrician but wanted advice from the electrician gurus about regs and stuff. Is it all good to keep that old unit in place for now? I’ve read mixed messages some people saying if it has that old box then means the wires are old too which apparently may be the older type wires that don’t have long life or something along those lines and some people were saying the fusebox needs replacing. And others were saying it can be kept as it is for now. If that’s the case at what point would i need to look at changing it? Just trying to plan ahead. Could temporarily the fuses be replaced out for those retrofit mcb type flick switches. Ive seen quite a lot of them around where you replace the actual fuse with a mcb style breaker on each fuse. Ofcourse I understand this isn’t going to be long term.
Also wants the rules in regards to getting electrical certificate to certify the electrics for piece of mind. And how often does it need doing?
