I can understand that. However, and a bit ironically, "up to" has another problem, but in the opposite direction from your concerns - since, in the real world, very few things have "absolute maximums" (or "maxima" if you're ancient and Latin-speakingJohn I pretty much a agree with all that you have said but I am always wary of "up to" etc as an advertising ploy and some folk do misuse it, when looking for a realistic norm that can be relied upon to some extent it does not easily give confidence
We had an issue back in 2017 when installing a stage lighting bar in a new school building where the builder asked for a SWL. We quoted the SWL ratings of the fitting's we'd attatched to the mounting framework they had installed but made it very clear we could not rate the frame they installed. We were then asked to load test the system but they were not prepared to accept responsibility for their framework. I don't know what the outcome was but there were many messages back and forth.I can understand that. However, and a bit ironically, "up to" has another problem, but in the opposite direction from your concerns - since, in the real world, very few things have "absolute maximums" (or "maxima" if you're ancient and Latin-speaking) (or absolute minimums) - so, whatever "up to" figures is quotes, there will usually be instances which are above that figure!
When testing of manufactured products can only be done by destructive methods (as in 'weight bearing capacity' etc.), quality control cannot involve every product which is manufactured, so one has to rely on 'statistical quality control', whereby a random sample of products is destructively) tested. That enables one to estimate the probability of an actual product having a value above or below some specified threshold. However, that 'probability' means the proportion of a large number of products that would be expected to be above or below the threshold, but it can't tell you which ones will be in that 'proportion' - the 'next one that one uses' might be one of those in the (perhaps tiny) proportion which are below the threshold!
Yes John I will buy that statement, it does not give me any problems, in most of life we tend to make statements with a broad, perhaps loose, general meaning rather than an absolutely exact, literal or technical meaning, we use language which is good enough for everyday use unless we are making a technical or lawful point about something , so long as it`s good enough for the purpose in hand and not deceptive we are mostly quite at home. It is when something is likely to deceive that it starts to concern me. Wild claims and exaggerations to exaggerate annoy me quite a bit, whilst innocent self deceptive statements do not cause me such great offense .I can understand that. However, and a bit ironically, "up to" has another problem, but in the opposite direction from your concerns - since, in the real world, very few things have "absolute maximums" (or "maxima" if you're ancient and Latin-speaking) (or absolute minimums) - so, whatever "up to" figures is quotes, there will usually be instances which are above that figure!
I am not allowed to comment.
It's over 60 years since anyone last tried to teach me Latin, and I suppose the correct (Latin) plural depends upon what declension the word is in (and "don't ask me"Minimus/ minimi ?
Exactly - and I think a word like "typical" (or even "average") probably fulfills that ('everday usage') role, doesn't it?Yes John I will buy that statement, it does not give me any problems, in most of life we tend to make statements with a broad, perhaps loose, general meaning rather than an absolutely exact, literal or technical meaning, we use language which is good enough for everyday use ....
Yes, but when it comes to technical or legal issues 'we' have to remember (but often don't !) that so many of this things are, in fact, probabilistic - such that "certainties" just do not exist - so that people looking at the figures must (should) accept that and take it into account...... unless we are making a technical or lawful point about something ,...
Agreed. I think that, in practice, a high proportion of the statements which may potentially mislead (because they are not really understood) do not exist as deliberate intentions to deceive or mislead but, rathwer, out of 'ignorance'; or, more commonly because there is often no 'perfect' (right' or 'wrong') way of conveying the information ...... so long as it`s good enough for the purpose in hand and not deceptive we are mostly quite at home. It is when something is likely to deceive that it starts to concern me. Wild claims and exaggerations to exaggerate annoy me quite a bit, whilst innocent self deceptive statements do not cause me such great offense .
As does Jeremy Clarkson when he talks about his SheepsIt's over 60 years since anyone last tried to teach me Latin, and I suppose the correct (Latin) plural depends upon what declension the word is in (and "don't ask me"). However, one sees a good few 'lniguistic pedants' insisting on "minima" (but not the two alternatives you mention), so I suspect that may be the correct one!
Whatever, I speak and write English, not Latin, so I generally form plurals of English nouns by adding and "s", or "es" !
Of course you are and your comments are always welcomeI am not allowed to comment.
Quite so. It's not often that I 'walk away' from these 'discussions about words', but this time it became so silly that I did.Jesus wept. I do not understand the pedantry and backbiting.
I agree..... Aren't those of us whom are competent in our respective fields are supposed to be here to help DIYers? Increasingly, I understand why @jobandknock left. And, yeah, I miss his advice. .... All to often, threads become an exercise in dick waving and, on the balance of probability result in the OP walking away. In no way am I suggesting that I am blameless. I "contribute" to this site because it helped me years ago (quid pro quo and all that). And I don't doubt that many of "you" are the same, nevertheless, the petty arguments possibly harm this site- which exists to generate income for the owners. They enable use to help other people, however, which passing diyer is gonna be arsed to see people having spats?
Perhaps, but those who run it have an ongoing need for income, so would probably allow it to persist so long as there were plenty of 'contributors', even if most were contributing little more than non-helpful (often silly) arguments with one another! Forums which seem to be designed for contentious and heated arguments often do very well in terms of 'post count' (and advertising income)..... We abuse it, and we will lose it.
