If no earth then one would not get a shock anyway. It would need two faults to get a shock, one neutral to touchable metal, and one line to touchable metal, and it would need to be from same RCD.Not much use if theres no earth
Ah, my bad. I misread it as does not throw...The RCD is one of the few things that might be OK?
I took this to mean the RCD test button is working as expected.
That is a good point, however even with an RCD which is working A1, in a home where the earth bonding is correct, I found the hard way, when making a channel down a wall with two hack saw blades for a water supply to the fridge, one people don't keep to permitted zones with electrical cables, and two even if the RCD does trip, touching line can knock one out.Just as an aside - A fully functioning RCD does not need an earth to enable it to trip, people and equipment often need an earth where relevant to reduce voltage difference to safer levels until that trip occurs.
I plug in, select loop, press button, and if 0.3 or less, I know it is OK, the pass mark for a ring final is 1.365Ω for a non RCD protected socket. My meter is for DIY and still cost around £75, it also tests the RCD, but to reset quite a walk so did not take a picture of that. A professionals meter would have another decimal point at least.
so it says, I used one with the caravan to ensure line and neutral correct way around when abroad, but not much else.Was interested to learn about the old steel conduits in these systems being used as the cpc. Will update when I get a satisfactory result
If I remember correctly they sent 25A thru as the test current, bad joints were shown up but also the the fizz bang crackle had the tendency to weld the joint to such an extent that it actually had a tendency to cause a weld which might have caused a bit of continuity correction as a result.In the 80s, when I used to install galv conduit as the CPC, i had a high current test meter that would check all joints were well made. Any that were not, you would hear crackling.
No, not me.I have not seen one for a while though. Ho happy days!
