- Joined
- 27 Jan 2008
- Messages
- 28,742
- Reaction score
- 3,508
- Location
- Country
I want my boiler to work even if there is a power failure, OK mine will, I have a 5 kW inverter and 6.4 kWh of battery and solar to keep it running. But most people don't have this, so in a power cut to have a small generator outside and an extension lead going to the boiler would make sense.
However, most boilers seem to have a FCU not a plug and socket, so hard to plug into a generator in an emergency without the use of a widow maker, also need a locking off device designed for that make of FCU, to lock the switch off. (The fuse only supplies line, so neutral still connected so technically not isolated) Where if using a 13 amp plug, where these
are universal for all 13 amp plugs.
The only reason I can think of, was some regulations back, we did not need to protect FCU with an RCD, however buried cables in wall rule has in the main change that.
Asking on Plumbing section as I am sure most electrics would like me not know why the FCU is used, other than it says so in some boiler manuals, likely written before the rules on RCD's changed. So other than that's the way we have always done it, why would one use a FCU to supply a boiler? As to being able to unplug locking sockets would stop that
so why are FCU used to supply boilers?
