We have bought a replacement built under oven Kenwood KBUDOX21. One online site says it is "plug and play" install, others that it needs hard wiring to a dedicated cooker circuit/switch.
We have a red switch in the kitchen (pictured) and a separate circuit breaker on the consumer unit.
I have looked behind the existing oven (Whirlpool AKG668) and it is plugged in with a plug (thick wire) into a normal double socket, with the socket linked to the red switch above the counter.
My question is, can I simply switch the wire from the back of the existing oven to the new (power off/unplugged!), or does the socket/wiring need to be replaced? The double socket also has a plug to the extractor fan.
Thank you
Thank you
