- Joined
- 31 Jan 2023
- Messages
- 60
- Reaction score
- 4
- Country
I live in a bungalow built in 2002/3. The top case of the CU sits 100mm below the kitchen ceiling inside a wall cupboard. Under said cupboard is a small fridge, thus getting to the CU requires low steps and removal of the Beans and Pasta to access the breakers etc.
There is no other place for the CU in the kitchen, so the replacement larger CU has to go back in the same place but 25mm higher to fit inside the cupboard, which will now be 75mm from the ceiling. There will also be a second CU feeding a planned HP and Solar setup. The reason for the replacement CU is the plastic case and no room for a new EV circuit.
Before I start hearing that infamous 'sucking in through the teeth' sound when obtaining quotes for the actual electrical work, I'd rather know for sure if I will be told I've been very naughty for not adhering to best practice, or will be dragged out of my bed and shot in the head for a major crime.
What say the sparky's.
