Apologies iff i got that wrong somtimes my brain will go off on a tangent and miss crutial information --again sorryOK different way...
12v x 20ah x 5batteries = 1200wh. My 60 was 60v, x 20ah = 1200
Yes, has been my worry when riding the canal tow-path, any problem, be it a battery or a puncture, how do I get back?Throw a tow rope in, attach each end, to each end of the handlebar, and tow it up the hills. Mine has proper brake levers, but I don't know what you might do, to tow one with an automatic, mag brake.
My mobility scooter was my mothers. And it was too fast to keep up walking, and too slow to ride a bike with. I carry an aerosol to help with punchers, plus a normal puncher outfit. The motor is in the hub, so will still drive with no chain, and if battery flat I can peddle. But I don't go out if there is no one who can pick me up in a car. Even if it means half mile or so to get to where a car can go.
You are lucky to live in Wales (never thought that I would say that). Most E-bikes on TFL trains are banned.I can get e-bike on the train,
The 20 isn't the volts, it's the ah. 12 volt x 20 ah x 5 = 1200 Whthey are 12v not 20
volts times amps = watt, not Wh.to get the the watt hour you multiply volts times amps
That's right, I agree with your 1200 Wh.The amps, is amp hours, so the result is watt-hours.
Amps and amp hours are not the same.The amps, is amp hours, so the result is watt-hours.
Hopefully you can see from all the confusion that has arisen from you using A when you meant Ah how important it is to use the right units at all times.
You did. It was big-all who introduced the confusion, by talking about 'amps' when he/she should have written Ah ...If you mean me, then I did use the correct terms..
You did - sorry.If you mean me, then I did use the correct terms..
