What evidence do you have for that?AFAIK, the charge port is only connected to the battery.
you are missing the diodes that exist to address the problem. Google mobile phone charger circuit diagram.
The battery is either being charged or supplying power, it cannot do both. You have the same scenario in a solar panel, where you do not want the battery to power the panel. with the Phone the incoming power goes in to a rectifier and an arrangement of diodes that mean the phone is powered either by the incoming power source while the battery is charging or the battery when it is not charging. The diodes prevent the electricity flowing the "wrong" way.Explain.
When I charge my 'phone, I can still use it.
Depends on what apps I am using, it can recharge, discharge, or remain at the same level of charge.
I also doubt that the charge port is directly connected to the 'phone's gubbins; only via the battery.
From this, I deduce that the 'phone is always powered by the battery.
And that the battery can be recharging while also discharging.
You tried this yet Harry?
Those motor movers are brilliant aren't they my old caravan had one could get it anywhereNo need, the caravan is quite capable of moving itself, using its own motors and battery.
I got about 7 miles from a new 12 volt leisure battery that was bedding in for sale, don't recall amp/watt hoursJust how far do people go on these moability scooters? I didnt think they were this advanced and was used mainly for hopping about localy for a few miles? Never really thought about them doing distances.
Current, electrons, can only flow into, or out of a battery
Is that you?You tried this yet Harry?
How could you tell?Is that you?
