Brass tube, or plated steel?
18 Apr 2022
I've got a coat rack which is partially made of steel tubes with a naff-looking brass coloured (sort of) plastic coating, and I want to replace them with real brass. They're about 1m long, one has 5 or 6 hooks for coats, the other is bare for hangers to be hooked over.
I've noticed that some people selling tube for wardrobe rails are using brass plated steel. Is this purely for cost reasons, or is it because brass would bend?
I'd be using 19mm tube with 1.5mm wall thickness, or possibly 16 gauge which is a tad thicker, so reasonably sturdy, I think, but would I be better off using plated steel?
That's assuming I could even get plated steel with an I/D of 16mm - that matters because the ends slide over some other tubes which are about 16mm O/D.
Yes - the whole point of the exercise is to make it look better - it's not a rail in a wardrobe.
It's the rail at the front (and back, with hooks on, but you can't see that very well in the photo) which has the sort-of-brass-coloured plastic coating. Don't think that galvanised tube would be much of an improvement. And anyway, 20mm is too big.
This is why O/D matters:
And this why I/D:
Walk in b&q and they sell brass and chrome tube for wardrobes or worktop support.
They also sell bar to make curtain poles with various fittings.
You can also Google brass foor bar for another option.
You could also use copper pipe and polish
Can't see any 19mm brass wardrobe rail in B&Q, only brass plated.
Can't see any 19mm brass curtain rods in B&Q, only brass effect.
So they make foot bars out of 19mm tube with a 1.5mm/16ga wall thickness?
Does that work well?
What polish should I use to make copper look like brass?
Also, I always thought that brass was stronger than copper, but your suggestion would indicate otherwise. Can you refer me to any properties data which confirms that copper is stronger than brass?
Copper is probably going to be too soft as you say.
As for brass foot bar I've seen it being used and fitted but not my area of knowledge.
Bit of a specialist area this Vs general DIY.
Foot bars in pubs and bars is generally a lot bigger than that - the type I've fitted were 50mm diameter and over
Brass is harder and stiffer than copper. For maximum load bearing you need to look for oval tube rather than round - far stiffer so will carry more weight over a given span. This is what I mean
Why round, though?
TBH as far as round copper pipe goes it is actually far easier to get hold of than brass, mainly because it is still widely used in plumbing (although that is changing in commercial work). The main thing to be aware of is that for a given pipe size it isn't as stiff as brass would be, so it's more likely to deflect under load, or possibly need more suspension points. You'll struggle to change the colour of copper in any durable way without resorting to having it plated. If cost is a major consideration surely polished brass finish steel tube would be better, like this stuff. More expensive than copper, but stiffer than copper or brass. You may need to make your own end plugs up, though
Why round, though?
No - cost isn't an issue, I only need a couple of m and brass is only a few quid more than plated steel.
As long as the OD is 19mm/¾" it will fit these:
and as for these:
I'll get some replacements 3D printed anyway so that they are black to match.
