I have a stud wall currently open on one side, bathroom / airing cupboard etc to bedroom. It will have tile backer / MR Plasterboard soon. I also have some large chunks of foam from several mattresses (not memory foam topper, the large support material yellow coloured Polyurethane (?) foam). It's easy to cut with a carving knife and I can easily fill the stud wall with foam prior to boarding.
I was wondering if this was a good idea. It had nothing before and I figured it could help acoustic transmission, and help me use up the foam. I know there are other 'proper' (expensive) materials that may be slightly different or denser foams but my question is about using mattress foam.
It's talked about online for similar such uses, and it's suggested that building insulation would be a good avenue for recycling mattress foams but my only concern is in 10 years if it decomposes and goes all sticky and rots due to lack of air, like a foam lined flightcase opened for the first time in a decade, with flakey sticky foam all over your mixer desk? Though does this even matter?
I also have lots of Jobolite Polystyrene board I could use, but figured the much higher density of the mattress Foam would help?
Any thoughts?
Any thoughts?
