- Joined
- 27 Jan 2008
- Messages
- 29,306
- Reaction score
- 3,600
- Location
- Country
At work the electrician has a battery tester which prints out a sheet showing what is wrong with the battery. In the main I simply did not question the results, however we use in the main AGM batteries for the carriage lights, which are used at the beer festival and Father Christmas trains, so no heavy load, and can easy be missed at to getting them recharged.
So I have put batteries on charge, and they have been good enough to start a generator, but have been previously shown as US with the battery tester. In the main I visit once a week, every Wednesday, so I have been using a small Lidi charger 3.8 amp, which will auto turn off once battery charged (14.4 volts), and back on should the battery voltage fall below 12.8 volt. And since only there once a week, either 1 or 2 weeks on charge, then charger moved to next battery.
But it seems we are scrapping good batteries, because of this fancy battery tester, except for an emergency, these batteries do not start engines, they are used only for lights.
